Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
    Join Date
    Aug 2009
    Posts
    108
    Default Re: Seacocks and Skin Fittings/Thru Hulls
    Any tips on source of wooden bungs? Clearly for this purpose, and also for emergency purpose, we only need a couple of sizes; I am struggling to find them except in sets of 6-8 where only two are useful.
  2. #12
    Join Date
    Apr 2016
    Chichester
    Posts
    795
    Quote Originally Posted by asteven221 View Post
    Although plastic offers many attractive features and i can see the benefits, I am still not 100% convinced of their longer term reliability. There are stories about them snapping, which just backs up my instinct about using plastic. Perhaps they really are much better than DZR, but I am happy to stick with the tried & tested this time around.
    TruDesign are a glass-reinforced nylon composite. I've just fitted a second and, frankly, will not now use anything else. Marelon ones had some previous problems of handles snapping.
  3. #13
    Join Date
    Nov 2008
    Posts
    7,052
    Quote Originally Posted by RJJ View Post
    As a practical boat owner, I am speechless. Sorry.
  4. #14
    Join Date
    Nov 2001
    Me: Johannesburg South Africa Yacht: Richards Bay East Coast Africa
    Posts
    7,347
    Pipe threads come in tapered or parallel.
    Internal pipe threads in pipe fittings are generally all parallel but external threads can be either parallel or tapered.
    A tapered external in a parallel internal thread can be tightened a but more to get the orientation of the fitting correct.
    With parallel threads in to parallel threads unless you one to the end (bottom) of the thread it will not lock in that position.
    One way is to ue a lock nut the other is to adjust the bottom position by filing/grinding the bottom (locking) position to get the correct( required) orientation. This is the way I prefer but does need a little work/skill.
    Life is too short not to have a sea view
    Distantshaws tinyurl.com/yclt6l68
  5. #15
    Join Date
    Nov 2001
    Posts
    7,347
    Quote Originally Posted by NormanS View Post
    If RJJ cannot make some from some scrap wood lying around, he could get some rubber stoppers from a local lab supply company.
    https://www.google.co.za/search?q=ru...w=1517&bih=640
  6. #16
    Join Date
    Jul 2003
    Posts
    1,199
    I had a bag of mixed bungs and only 2 fitted, so I went into the chandlers for some more bags. At £7 a bag I thought sod that, so I got my sanding machine out and sanded them down as required. I found the softwood bungs can be a bit soft and you can easily drift of centre when drilling. I had a brush handle so cut that up for bungs. That was much better as the wood was harder, thus drilling was easier to control. When banging the bungs into the thru hulls it doesn't matter if the bung isn't a perfect circle as long it's in the hole sufficiently so that when you saw the excess off it is close to being a circle. All you need to do is make sure your pilot hole is dead centre of the thru hull hole.
  7. #17
    Join Date
    Oct 2005
    Oxfordshire
    Posts
    726
    Quote Originally Posted by Poey50 View Post
    I had similar comments "why would you trust a plastic through-hull?" when I went for Trudesign. My reply was "well it's a plastic boat". As said, they are glass reinforced so the same as the hull. The only downside I can see is that they are physically larger for the same diameter so you do need a little more space around them.
  8. #18
    Join Date
    Jun 2017
    Posts
    809
    A good chance to get some practice with the carpenter's hand axe!
  9. #19
    Join Date
    Apr 2018
    Mooring, Faro
    Posts
    1,987
    Quote Originally Posted by bobgarrett View Post
    An upside is that they still move with one finger even after months of being in one position, whereas dzr or bronze can get quite stiff if not regularly used.
  10. #20
    Join Date
    Apr 2016
    Chichester
    Posts
    795
    Fremdschamen-das-boot-nicht-praktisch - feeling in sympathy with someone being shamed for not being practical enough on a practical boat forum.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
