Page 3 of 9 FirstFirst 12345678 ... LastLast
Results 21 to 30 of 87
  1. #21
    Join Date
    Mar 2007
    Atlantic
    Posts
    21,781
    Default Re: Cunliffe's star gazing book
    Quote Originally Posted by Sandy View Post
    Totally agree, I have a first degree in engineering so lots of applyed maths and was totally confused by her book. It might suit somebody who likes pure maths?
    Yeah, there are obviously some fans. But I can only really repeat the feedback from the dozens of people who we have taught over the years who simply don't get on with it. Actually, not a single one!
  2. #22
    Join Date
    Jun 2007
    Home: North West, Boat: The Clyde
    Posts
    3,764
    I also have a degree in engineering. There is no pure maths in the content. There isn't really much applied maths. In the Foreword, the former director of the RIN describes the book as "admirably concise". Perhaps this is the issue; there isn't much by way of explanation, rather, she dives in with worked examples.
    There is nothing really difficult about taking and reducing a sextant sun sight to a Position Line. The procedure is simply to compare the angle measured by the sextant with the same angle calculated from the exact same time as recording the sight. Most of the sight reduction process is "look-up", either in a Nautical Almanac or a Table of Trigonometry (AP3270/aka Air Tables). There is very little maths but many people stumble with what was as a child, mental arithmetic. Adding and subtracting degrees, minutes and decimals; sign convention for West and East etc.
    Due to the concise nature of Mary Blewit, it is a very good book as an aide memoire or for revision. I've said in a post above that it's not the best text book but it doesn't warrant this negativity.
    Celestial navigation is not the easiest self-study course. I haven't taught dozens over the years but from those I have it's rewarding to witness the Eureka moment when the concept is grasped. Most people seem to need a helping hand to get over the first hurdle of understanding but from that point on can progress well.
    Many people use Templates to help the sight reduction process. I don't use them myself but, of course, I teach their use. It's quite insightful to see if students use the template or can reduce the sight/time without one
  3. #23
    Join Date
    Aug 2011
    On the Celtic Fringe
    Posts
    14,505
    Quote Originally Posted by davidjackson View Post
    Thanks for an interesting post David.
    It sounds like it is a bit of a "Marmite" book. I was lucky enough to do Navigation at school and was introduced to Mary's book at the age of 15. I picked it up again at the age of 45 and quickly put it back down. It's a bit like some maths teachers, some are on your wavelength others appear to be from a parallel universe.
    In the next few years I am planning to submit a passage for the RYA Yachtmater Ocean ticket and know a) I need to produce some celestial nav workings and b) am actually interested in the subject. I've had several discussions with Ocean qualified navigators to discuss what works for them and several have suggested other books and YouTube channels.
    As I finish working full time in 2020 I'll have the time to play with all sort of celestial nav and will get back to you with what works for me.
    Cynical Scottish very nearly retired engineer who sails a Gib'Sea 96.
  4. #24
    Join Date
    Dec 2007
    Boat: Falmouth. Work: Cambridge
    Posts
    1,402
    ...It might suit somebody who likes pure maths?
    Nope. It obscures the underlying simplicity and makes it all too complex. In fact I believe they all do to some extent as they put over emphasis on the calculations; I suspect because none of the authors actually understand them.
    I think the best is to use a computer program on some trivial thing like a cheap smart phone or ipad and not worry at all about the calculations nor even looking up ephemeris until actually taking a sight and plotting it becomes absolutely second nature. Then, if one can be bothered, one can start to look up the GHA and Declination - checking what one has looked up agrees with the computer, which gives confidence. Then progress to using pre-computed sight reductions, still checking the Computed Altitude and Azimuth against what the computer says.
    That way the computer program becomes the most important teaching aid.
  5. #25
    Join Date
    Aug 2011
    Posts
    14,505
    Quote Originally Posted by jdc View Post
    Having spent my working life working with some very big computers I am planning not to get too involved with them when I stop full time work. Being a simple engineer I usually took to diagrams on bits of paper to describe what I needed the coders to do on the computers... To quote one of my maths lectures, "Does it look right", has always been a good starting point, using a computer wipes out looking at the maths so I would have no idea if it looked right or not! Please note that if I don't get it right in the day job undertakers are going to have a very profitable time!
  6. #26
    Join Date
    Jun 2007
    Posts
    3,764
    Sandy,
    With your “pencil and paper diagram” mentality I assure you that you will have no trouble grasping the concept of sight reduction. With your background there’s absolutely no reason to delegate the task to electrickery.
    One to one is the ideal student-pupil ratio for this course. Do you know any approachable, helpful, friendly, flexible, knowledgeable, experienced, informative, affordable, like-minded retired engineers, qualified to teach it
  7. #27
    Join Date
    Dec 2007
    Posts
    1,402
    ..Being a simple engineer I usually took to diagrams on bits of paper to describe what I needed the coders to do on the computers...
    Well, it's only a calculator, so not exactly a main-frame I meant! And the program I use I wrote myself.
    I don't believe however that the trigonometry is tractable, and certainly is not to the accuracy required, without numeric methods; graphs and lines simply won't cut it. Using haversines etc are obsolete methods now and should no longer be taught as part of astro-nav imho. My essential point is that it's absurd to conflate repetitive, mindless, calculation and the human skill of taking an accurate sight and using it to determine one's position. Yet this is what most books do. Expanding on tis point, I have always felt that the concept of a 'noon sight' to be obsolete; it's emphasised by those who are afraid of doing the sight reduction due to the bore of the arithmetic.
  8. #28
    Join Date
    Mar 2007
    Atlantic
    Posts
    21,781
    Noon sight?
    It's perfectly brilliant. I showed someone how to do it in half an hour last week. On first go his position was 8 miles out. In relative terms, excellent. It's not just latitude, you get arc to time longitude as well.
    Maths, who needs complicated. It's a simple bit of adding up and taking away. Calculators.... Duh.
    Get yourself a Davies sextant. Read the accompanying very small handbook and hey presto!
    Don't believe anyone who poses that it's difficult. Ask people who have taken sights on ocean passages how simple it is.....
  9. #29
    Join Date
    Jun 2007
    Posts
    3,764
    That's an interesting assertion. Why would you not take the opportunity for a relatively simple to derive measure of latitude?
    As to trigonometry, the easiest way to derive DR from last fix is to use Plane Sailing methodology. Use Quadrant Notation for bearing plus a simple Sine and Cosine calculation. I still have my 4-figure Log Tables from the 1970s but I'll admit to using a pocket calculator This method is also idea for the "run" between forenoon and afternoon sights as it's more accurate than using the Plotting Sheet. (The Traverse Table in Nories does the same calculations but as a look-up).
    Most people learn sight reduction using the Intercept Method, Marcq St Hilaire so Haversines not needed.
  10. #30
    Join Date
    Mar 2007
    Atlantic
    Posts
    21,781
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
