Results 1 to 6 of 6
Thread: sea cocks
  1. #1
    Guest
    Default sea cocks
    INFORMATION REQUIRED ON FIBER GLASS / PLASTIC SEA COCKS (AGENTS & FITTING INFO ETC)
  2. #2
    Join Date
    Sep 2001
    Posts
    18,327
    Default Re: sea cocks
    ASAP supplies do them, they are excellent units and fitting is basically the same as for any other.
    If I agreed with you we'd both be wrong.
  3. #3
    Guest
    Default Re: local plumbers merchants
    Why pay over the top ,try your local merchants first ,as long as you use a good sealant and don't over tighten the fitting things will be fine
    Mick
  4. #4
    Join Date
    Sep 2001
    Posts
    636
    Make sure you get GRP not plastic (handles break off) and make sure you get ones that are type-approved for marine use for below-waterline thru-hull fitting or else your insurance may not pay out if they fail and your boat sinks!
    Regards,
    Jerry
  5. #5
    Guest
    Here in the US the brand name and material name is "Marelon". These seacocks and thru-hulls are made of a black colored material that is extremely strong. Mr Hawkins was definitely correct when he said to make certain you obrtained thruhulls and valves made for and intended for below the waterline use since you certainly don't want an insurance problem or a sunken boat.
  6. #6
    personally mick I wouldnt touch a plastic stopcock from the local plumbers or builders merchant, the chromed brass ball valves are ok but gate valves and plastic valves.. NO THANKS
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
