Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 70
  1. #41
    Join Date
    Jul 2001
    Posts
    7,003
    Default Re: alright then
    Ok, My boat has 3 seasons of 'normal' antifoul applied, so for next season I intend to scrape it all off and start again. What would you recommend?
    It's a 35' 38knot motorboat, located on the south coast and does a couple of hundred hours a season.
  2. #42
    wakeup's Avatar
    wakeup is online now Registered User
    Join Date
    Mar 2002
    Posts
    2,612
    Coconuts according to scuttlebut, apparently they don't get fouled on their sea journeys to new islands.
    Get your self a load of bounties mashed up in some copper coat.
  3. #43
    Join Date
    Jun 2005
    Posts
    52
    well the antifouling i produce can be used in all sort of waters. it has also been approved by the enviromental agency. There should be no old antifouling on the hul before you apply any new stuff as this would peel. this can be removed by sand blasting, or you colud alternativly use strippit. an antifouling remover we also produce.
    Copper plus (my antifouling) lasts for up to 10yrs if applied correctly. It only needs to be power washed every so often to remove weed around the water line. or you could just take a dive down and wash it off with a cloth. It is also self cleaning so if you take the boat out most of any weed that builds up around the water line will come off.
    Boating Ladette
  4. #44
    tcm is offline Registered User
    Join Date
    Jan 2002
    Posts
    22,500
    Default scraping it all off
    i can recommend removall 610 as a quick way to get back to bare grp, beats lots of scraping.
  5. #45
    Join Date
    Jul 2001
    Posts
    7,003
    Milk or plain chocolate?
  6. #46
    Join Date
    Jun 2005
    Posts
    52
    i would reccomed Copper antifouling. It last so much longer up to 10yrs. It is easy to apply and only needs occasional power wash. if that!!
    Boating Ladette
  7. #47
    Join Date
    Jul 2001
    Posts
    7,003
    Default Re: scraping it all off
    'Removall 610' Is that genuine or will it melt my grp?
  8. #48
    Join Date
    Jun 2005
    Posts
    52
    Also another product that removes old antifouling is 'strippit' You just leave it on over night and blast it off in the moring
    Boating Ladette
  9. #49
    Join Date
    Jan 2002
    Posts
    22,500
    nope, genuine stuff, use google to find uk stockist. I used it and didn't melt grp,. specially designed for the job, lifts the paint so qucik liftoff with massive scraper for easy disposal is best option (and not blast with a jetwash until mostly all off) - 2 of us got a 76foot hull totally clean in a single day. Halve the qtys they say you need, bosh it on with a brush, leave overnight.
  10. #50
    Join Date
    Jul 2001
    Posts
    7,003
    How much does copper plus cost to apply to as 35' boat and what makes it different from copperbot?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
