Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    May 2001
    Broken Brexit Britain
    Posts
    45,512
    Default Flat screen TV\'s for boats
    Thinking about buying one. Any recommendations on size and type? Do they stand up to being bounced around?
  2. #2
    Join Date
    Sep 2004
    Sussex
    Posts
    326
    Default Re: Flat screen TV\'s for boats
    I bought a Sharp Aquos 15" for the F1 a couple of years ago, it's pretty robust and not been treated all that well, still looks and works like new.
    Shop around on kelkoo or deal time, I got a £550 TV for a little over £400.
  3. #3
    Join Date
    Jun 2005
    Posts
    84
    Get a 12v one then it can be run on shore power or 12v.. Only 1 problem is that only the cheaper have the 12v socket (cheapest isnt always very good).
    We settled for a DMTECH one from Comet with built in DVD player and its all from 12v and was around 450 pounds but it does have a very nice quality image.
  4. #4
    Join Date
    Oct 2001
    up north
    Posts
    645
    Im with Thomshap
    I have a Sharp 13" LCD, you can also get a 12 volt adapter to run it.
    has a nice carring handle on it aswell.Good picture and easy to set up
    Ian
  5. #5
    Join Date
    Sep 2004
    Posts
    100
    Sharp Aquos LC13S1E, recently installed and very happy so far. It runs on 12 & 240 volts and is multi standard. There is a slightly different and cheaper model which is mains only. Mounted an a bulkhead bracket multi swivel thing. Have not really bounced it around yet.
  6. #6
    Join Date
    Jan 2002
    Caribbean at the moment
    Posts
    23,960
    mine are somehow secured into the walls, with no prob of being bounced around. I suppose the engineering job gets proportionally bigger with size of telly. The ornery comet-supplied stands for biggish flatscreens don't seem solid enough really, even if nailed to a surface.
  7. #7
    Join Date
    Apr 2004
    Posts
    7,649
    Have 28" LCD in saloon and 15" in cabin and both seem to have stood up to the normal rigours of being on a motor boat fine. I think you can only get 12V up to about 17", so if you want a bigger TV in saloon will need to be 240V.
  8. #8
    Join Date
    Oct 2002
    north lincs.
    Posts
    1,486
    originally bought a Goodmans 14 inch from Macro in winter took to boat a month ago and found brilliance not very good set at 100%,went back to Macro and the one on show was dull also even when set at 100%,saw a Sharp 15inch which was fine.Only prob.it was 240v, put on my inverter and works v.good, much better than the goodmans.and its nicam!! Cost me £8 more as it was on offer.
  9. #9
    Join Date
    Jan 2004
    Jersey
    Posts
    2,711
    Flat screens are not a problem in principal but the way they are mounted might be. TVs designed for living rooms often sit on purpose made stands and even if held by screws would be far too wobbly for a boat.
    Look for models that use the VESA 100 or 200 mounting standard. This will give you 4 mounting holes on the back of the screen at either 100 or 200mm apart. There may be others that don't fall into this standard but provide similar multi-point mounting.
    On our P42 we used a gorgeous little Panasonic 15" widescreen TV. Bumps and rolls never affected it at all but it was mounted on a solid stainless bracket.
    I've chosen 2 different Panasonic TVs for the P67 - this 32" HD one for the saloon and this 17" one for the stateroom. Both have the required 4 rear mounting points and will be mounted on custom stainless stands/brackets.
  10. #10
    Join Date
    Jul 2002
    Faversham kent uk
    Posts
    3,281
    http://www.empiredirect.co.uk/conten...-LE15E31SX.htm
    got this one for £227 very good telly but my kids have nicked it ! I will have to buy an other, yes bounces well off and on the boat !
    Tom
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
