Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
  1. #1
    Join Date
    Mar 2004
    United Arab Emirates
    Posts
    82
    Default Diesel engine fresh water flushing - Does anyone bother?
    Many of my friends fush their outboard petrol engines with fresh water after every use in saltwater.
    My engine - volvo 2030 with raw water, heat exchanger and fresh water 'internal' cooling. Would I help extend the life of my engine if I fitted a Y valve to the raw water intake before the pump so that I could hook up a fresh water hose and flush out the salt every now and then? I understand that the outboards need it more as they are entirely salt water cooled but I thought that by flushing I could help my engine last longer.
    Has anyone tries this? Is it worth it? or am I being over protective of my pride and joy?? PS my boat is in arabian gulf so very salty!
  2. #2
    Join Date
    Feb 2002
    UK
    Posts
    683
    Default Re: Diesel engine fresh water flushing - Does anyone bother?
    If you are about to leave your boat for a month or more it could arguably be worth it, but not for shorter periods. I flush mine out well when laying up and follow up with anti-freeze for the benefit of the inhibitor it contains, but I never bother at any other time.
  3. #3
    Join Date
    Jun 2004
    Derby
    Posts
    517
    As Medman, I have just hauled out for the winter as I need some work doing on her. Have a Volvo 2003T, I disconected the water inlet and connected a hose pipe and ran the engine for a few minutes, then made a 50/50 antifreeze / water mix in a bucket and put the inlet into that and let it suck it through for its anticorrosive properties.
    I dont think the previous owner bothered and I had a pinhole appear in the copper raw water pipes a while ago, I am assuming this means that they all now need replacing.
    I also removed the pump impeller, changed the oil and filter and cleaned the air filter.
    Of course this is for a long lay up, I wouldnt bother for short periods.
    Re the y valve - nice idea and convenient, but its so easy to do any way Im not sure as to the need.
  4. #4
    Join Date
    Mar 2004
    Nr Plymouth
    Posts
    3,571
    Hi,
    I think it's well worth doing at lay-up, though probably not not during the season.
    FWIW, I flush my raw water cooled Bukh through (recirculating via a bucket under the exhaust) using fresh water mixed with an emulsifying oil. This coats the inside of the waterways with a film of oil and prevents rust forming.
    When I stripped the engine down for a major refit last winter, there wasn't a sign of corrosion anywhere, which can't be bad for a twenty year old (though well maintained) engine!!
    Cheers Jerry
  5. #5
    Join Date
    Jun 2005
    Mid Devon
    Posts
    6,040
    As you have a heat exchanger, salt water doesn't enter the engine. Flush the raw water system during lay-up and rod through all the water stack tubes to keep them clear.
    I'm still backing Britain.
  6. #6
    Join Date
    Mar 2004
    Nr Plymouth
    Posts
    3,571
    Hi Pershilla,
    Did you read my post? I have a RAW water cooled engine, so the emulsifying oil goes throough EVERY part of the cooling system!!
    Cheers Jerry
  7. #7
    Join Date
    May 2001
    Poole, Dorset. UK
    Posts
    1,089
    As the only bits the sea water passes through are the Raw water pump, heat exchanger and possibly the oil cooler, only worth doing before laying up.
    Brian
    Mysite
  8. #8
    Join Date
    Jan 2004
    Wiltshire
    Posts
    1,275
    Please see my earlier posts about my Yanmar problem. To flush out the engine I connected a jerrican of water by a hose clamped to the impeller intake and stood the jerrican on the bunk base. The water level in the jerrican was then higher than the impeller and probably higher than the siphon break in the exhaust. The piston rings jammed up and I was lucky not to bend the con rods. Any flushing water has to be sucked in by the impeller not gravity fed.
  9. #9
    bob_tyler Guest
    NEVER connect a fresh water hose to the raw water inlet. The pressure can damage the impeller. Let the impeller suck the water in from a can or bucket placed at the lowest point possible thus imitating its normal method of operation. The can or bucket can be topped up with fresh water from the gently running hose.
  10. #10
    Join Date
    Feb 2010
    Bristol
    Posts
    1,764
    Quote Originally Posted by jerryat View Post
    Sorry to drag back an old thread but this sounds like a good idea and I've never heard of it before. Is this relatively common practice to use some sort of oil to coat your raw circuit while winterising / laying up?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Find Boats For Sale
to
to
