Results 1 to 8 of 8
  1. #1
    duncan's Avatar
    duncan is offline Registered User
    Join Date
    May 2001
    Posts
    9,423
    Default attitude control systems - and their place in small boats
    Has anyone installed, or have installed, one of these?
    Friend with a small boat is fed up playing with his tabs and power trim and thinks it may be the answer.
    Particularily looking at the Menthe Marine product - full info can be found http://nzmarinespares.com/My_Homepage_Files/Page21.html
  2. #2
    Wiggo's Avatar
    Wiggo is offline Registered User
    Join Date
    Sep 2003
    Posts
    5,164
    Default Re: attitude control systems - and their place in small boats
    As far as I'm concerned, if we have anyone on board with attitude, they can sod off and swim home.
    The nicest thing about not planning is that failure comes as a complete surprise, and is not preceded by a period of worry and doubt.
    <span style="color:blue">
    http://www.nereid-charter.com
    </span>
  3. #3
    Join Date
    Aug 2004
    Posts
    1,097
    My Sprint was fitted with Bennett tabs so I fitted their Auto Tab system -it works a treat. Doesn't affect the leg trim so you still need to do that manually but takes away all the work of continually trimming the tabs. Very pleased with it indeed.
    Rgds
    Simon
    Ocean Deep
    Fairline Sprint
    Volvo 4.3GXi
  4. #4
    duncan's Avatar
    Join Date
    May 2001
    Posts
    9,423
    Is that a similar thing ? ie you manually set the attitude of the boat you want then swithc to auto and the unit controls the tabs to maintain the selected boat attitude?
  5. #5
    Join Date
    Jun 2003
    Posts
    1,602
    I think I need a lie down - I opened this post with eagerness, only to find I had missread attitude for altitude
  6. #6
    Join Date
    Aug 2004
    Posts
    1,097
    Sound's like it, trim the boat how you want it, set that attitude in the memory and then she will auto-trim back to that attitude whenever the trim changes.
    http://www.bennetttrimtabs.com/autotab.htm
    Edited to add the url....
    Rgds
    Simon
    Ocean Deep
    Fairline Sprint
    Volvo 4.3GXi
  7. #7
    I installed the Mente marine ACS A+ product on our S23 as the trim needed constant adjustment. Works a treat. We've got Eltrim tabs(electric) on the S23 and I also wired in the outdrive trim.
    Only issue was that the Eltrim's need to be positioned mid-position before you calibrate the unit.
    I ordered direct from Mente's http://www.mente-marine.com/english/product.html and I got the impression I was first customer in UK. You may be number 2?
    (no connection to Mente etc etc)
  8. #8
    duncan's Avatar
    Join Date
    May 2001
    Posts
    9,423
    thanks - will pass that on.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
