Results 1 to 4 of 4
  1. #1
    Join Date
    Nov 2003
    Posts
    73
    Default Mobile internet- Brittany
    We are cruising to Brittany in June/July and need mobile internet access on a laptop. Anyone had experience of this? GPRS or 3G with UK or French simcard? Your experiences would be useful.
  2. #2
    Join Date
    Dec 2002
    Posts
    282
    Default Re: Mobile internet- Brittany
    I understand St Quay Portrieux has WiFi covering the marina.
    Don't know what it costs though.
    Regards
    David
  3. #3
    Join Date
    Apr 2006
    Posts
    49
    I have a O2 mobile simcard that slips into a port on the laptop. It is expensive and quite a slow connection... but ... you can connect from absolutely anywhere there is a mobile signal.
    I am told that most modern fones can be used as modems too!
    It is a minefield and someone will always have a better/cheaper package than you!!
    Life is a **** sandwich - the more bread you have the less **** you taste
  4. #4
    mikef's Avatar
    mikef is online now Registered User
    Join Date
    May 2001
    Posts
    21,420
    I have a Vodafone Mobile 3G Connect card which I've used all over Europe. It's worked fine in every marina I've ever visited although I can't say I've used in Brittany. Its expensive to use so make sure you get the right tariff for your likely usage and then use it sparingly
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
