Results 1 to 4 of 4
  1. #1
    Join Date
    Jan 2003
    Posts
    4,434
    Default Sealine 450 statesman
    Hi anyone owned one of these. A customer has one which we use for school and charter. Her biggest problem is the sound from the exhausts. There appear to be no silencers on that model.
    At tick over it sounds positively agricultural. When cruising in anything other than flat smooth the exhaust outlets take it in turns to surface as the boat moves, and the vroom, (2 second gap) vroom (2 second gap) drives you mad.
    I usually have all the customers nod off on the fly on the return journey due to the hypnopic effect. I can just about get it to shut up in smooth conditions at 1850 rpm, over or below that and no chance.
    Anyone know of a cure???? such as a modification?
  2. #2
    miket is offline Registered User
    Join Date
    Jun 2001
    Posts
    1,842
    Default Re: Sealine 450 statesman
    I had straight through exhausts on my Broom 37 and as soon as the outlets came out of the water the noise was offensive.
    Had a long talk with Halyard Marine. Nice people and silencers sound good, water separator version especially. Unfortunately no room to fit!
    Give them a call.
  3. #3
    Join Date
    Apr 2002
    Posts
    4,675
    Have a word with Sealine, from memory when the 450 came out there was a number of changes in exhaust requirements, above or below water. With the result that early ones tended to be varied in spec and design.
    Brian
    http://www.kddpowercentre.com VSR charge and monitoring systems
    Sealine and Westerly Powercentre spares and help line
  4. #4
    Hurricane's Avatar
    Hurricane is offline Registered User
    Join Date
    Nov 2005
    Posts
    3,570
    Hi Clive
    When we got our T51 she had these exhausts fitted (in fact only one - the other had fallen off)
    So we had new ones (as recommended by Sealine) fitted
    We dont get a noise problem unless she is rolling badly - and definately not when cruising.
    However, we do get loads of diesel muck over the stern quarter - especially over the dinghy on the bathing platform.
    These pics might help if talking to Sealine - they've obviously made some changes here anyway.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
