News from YBW.com
Go Back   Yachting and Boating World Forums > Motor Boat Forum
Motor Boat Forum Jointly hosted by Motor Boat & Yachting and Motor Boats Monthly
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 17-08-07, 17:44
Moody's Avatar
Moody Moody is offline
Registered User
Default Nets in the Channel?
This is the result of my mate picking up a net right in the middle of the TSZ en route from Ramsgate to Calais, stopped him dead.
Dived into Dover for a lift and hold (only charged him 56 quid), where a yottie was saying that he had heard that the French equivalent of MAFF, or whoever where subsidising the fishermen to replace lost nets.
Hence the less scrupilous ones were dumping old nets to get new.
Anyone heard anytrhing similar?
  #2
Old 17-08-07, 18:23
pelicanpete pelicanpete is offline
Registered User
Default Re: Nets in the Channel?
I have my doubts a Stripper, et al, would deal with that mess...would it?
  #3
Old 17-08-07, 18:46
mjf's Avatar
mjf mjf is offline
Registered User
Location: w.london - boat on solent- RIB on Tidal Thames
A mate of mine picked uo a very corse net off the needles about two weeks ago.
£150 lift!
  #4
Old 17-08-07, 18:54
ian38_39's Avatar
ian38_39 ian38_39 is offline
Registered User
Cant believe that the french would do something like this knowing what a law abiding and uncorupt nation they are.
To sugest that they would use underhand methods to try and benifit from state aid is unthinkable. [img]/forums/images/graemlins/shocked.gif[/img]
  #5
Old 17-08-07, 19:18
petie petie is offline
Registered User
Good old Dover. One of the best.
  #6
Old 17-08-07, 20:28
oceanfroggie's Avatar
oceanfroggie oceanfroggie is offline
Registered User
It should get you home rather than calling out the CG or RNLI for a tow. I've rope cutters on both shafts for this very reason, and they have worked twice for me so far. One case there was some rope left around the prop but free of the shaft, so just impared performance so we got home, lift, hold, remove and drop in.
__________________
Ocean Froggie
  #7
Old 17-08-07, 21:29
Registered User
That is, indeed, very reassuring. Next time I'm lifted, I'll have one fitted (single shaft).
  #8
Old 18-08-07, 09:58
RogerRat's Avatar
RogerRat RogerRat is offline
Registered User
Did you see 'djefabs' one last year, 5 NMs' off St Peters Port.
Derek said the net was massive and bloody strong. It took the diver a while to clear it all too.
Here
__________________
If you're passing say Hi. It's probably Schnapps o'clock.
  #9
Old 18-08-07, 13:59
fisherman's Avatar
fisherman fisherman is offline
Registered User
I don't think anyone is purposely dumping this sort of stuff: after all, who is most likely to pick it up, given the time spent at sea? Strippers would be hard pressed to deal with that lot, you just tear off the fixed blade.
Nets get torn and snagged, and when there's a bit of ground sea they get unsnagged and float up.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
