News from YBW.com
Go Back   Yachting and Boating World Forums > Liveaboard Link
Liveaboard Link Especially for those who live on their sail or motor boats, or are planning the great escape from bricks and mortar. Hosted by Yachting Monthly magazine
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 03-04-08, 23:00
Jonny_H's Avatar
Jonny_H Jonny_H is offline
Registered User
Default Hydrovane Installation ... experience, pictures, customer service
Thought others might like to hear of our experience installing our Hydrovane. We bought at Southampton Boat Show and the unit was delivered (as requested) in January in extremely impressive packaging (5 wooden ended boxes).
Installation took one day when the boat was out of the water (after having spent several days studying the installation guides etc).
Before we began I had shaped two pieces of teak to fit the brackets so they would butt up to the transom. As the transom is quite flat the lower bracket (which is hinged) had a 1" piece and the top bracket (which is at a fixed angle and would therefore need a wedge shaped piece of teak) had a 2" piece cut.
The lower bracket was installed first. The slight curve in the transom was matched to the teak using a sanding disk on a grinder to hollow out the teak in the centre. Once this was bolted loosely in place we put the shaft in to align the top bracket:
(Note: We had to remove the boarding ladder as to mount the unit centrally although we would clear the ladder the port mounting hole fell exactly behind the ladder rail!)
The top bracket was then aligned the top teak pad was cut to fit. This was done my roughly measuring the angle we required and then planing the teak with an electric planer to the angle and offering up to fit until we got it right. We then hollowed out a slight curve again to suit the transom profile:
We then checked vertical alignment side to side looking from behind the boat and lining the shaft up with the rudder before drilling the holes for the top bracket.
Once these were drilled we fine tuned the length of the top tube to get a vertical fore-aft alignment.
We then removed both brackets and put sealant between the bracket and teak, the teak and transom, and the transom and backing pads on the inside. (The backing pads were made of 1" marine ply - we also had 3mm thick stainless washers on the inside).
We then refitted the bottom bracket and bolted it up - and then the top bracket and bolted it up.
Shaft re-inserted we then dropped the drive unit on the top and put the vane on - looks good:
However, the vane was too tall to allow it to swing through its full range when on a beam reach without hitting the gantry. We took some pictures and emailed Hydrovane in Canada on Monday morning. They replied at roughly 1am on Tuesday (UK time) with some more questions - the choice was a shorter vane or a shorter shaft. I suggested a call to discuss and at 6pm on Tuesday (UK time) Will from Canada called to discuss the options. The shorter shaft looked like a better option as it would make the installation stronger (less distance between the top bracket and drive unit). Will called their UK workshop on Tuesday evening and a new shaft was shipped on Wednesday morning which arrived on Thursday morning (today) with us.
We fitted the new shaft today:
(Note the drive unit is 10 inches closer to the top bracket - it is vertical - the mast in the background is raked which makes the shaft look angled!)
Looks good and with the vane on (forgot to take a picture) it misses the gantry by 1/8 inch! (Although we could drop the shaft another inch to get more clearance if we wanted to).
Hoping to get her launched this weekend for testing next week.
It wasn't an easy job to do (was very glad to have the father-in-law expert woodworker on hand to do the teak pads) - and took around 8 hours in total (plus a further 1 hour to change the shaft tonight). We were extremely impressed with the customer service from Hydrovane and the speed with which the shaft was exchanged (we are posting the longer shaft back to them next week) especially given the time difference between us and Canada we had to overcome.
I will report back in due course how it steers (reportedly very well!) but am impressed with the build quality and customer service. Not a cheap piece of kit - but looks like it will be well worth it so far!!!
Jonny
__________________
www.freewebs.com/jksailing
  #2
Old 03-04-08, 23:11
capnsensible capnsensible is offline
Registered User
Default Re: Hydrovane Installation ... experience, pictures, customer service
This is my most favourite bit of boat kit ever, I am a huge fan. The Hydrovane Club should be established. Done 2 Transatlantics on our boat with it. Best thing .
__________________
www.herculessailing.com
  #3
Old 03-04-08, 23:41
rjcoles rjcoles is offline
Registered User
Looks great, just what I need to do myself. I have looked at all the others on the market but the Hydrovane looks like the one for me (center cockpit ketch).
Does anyone have one for sale?
Richard
__________________
www.bay-yachtbrokers.co.uk Honest & Transparent Professional Yachtbroking
  #4
Old 04-04-08, 00:00
jonic's Avatar
jonic jonic is offline
Registered User
Well done Jonny. She really looks the part now. As you know I love mine, and their customer service is second to none. Just ordered a watermaker from them and they were brilliant. Arrived early here in Mallorca after coming from Trinidad.
__________________
www.jryachts.com Cruising and Bluewater yachts for sale (more required)
  #5
Old 04-04-08, 00:45
Registered User
Didn't mention, but the one tiny snag is the vane cover. Made of lightweight spinnaker material, does not enjoy cuddling the sun's rays. We are on our second, get spares or make your own spare, it will give up.
__________________
  #6
Old 04-04-08, 00:59
SimonJ SimonJ is offline
Registered User
Location: Returned to Devon in May/June 09 from Caribbean
We have 3 transats under our belt with our wonderful hydrovane. One thing I wish they had advised us to do on first fitting & should have considered for myself (but the rush was on) was to put plenty of Duralac (or similar anti corrosion gunk) everywhere a stainless bolt/washer was in contact with the cast aluminium. It did not take long for nasty corrosion products to arrive!
Otherwise in my opinion the best self steering there is!
One last thought - a good idea is to make up a rig to use a simple simple electric autohelm so that full use of unit can be made (eg if you have to motor) should you lose main rudder.
__________________
SimonJ
  #7
Old 04-04-08, 02:52
KellysEye KellysEye is offline
Registered User
As somebody else said, best bit of kit on the boat by a long way. Ours has done around 25,000 miles and I had no idea of the good customer service because I've never had to contact them (which is probably the best recommendation of all).
I agree the 'sail' cover gets UV damage so carry at least one spare. If you don't have a spare you can cover the frame with clingfilm or plastic bags (cut to fit) and tape to get by.
Also the rudder pins have been known to bend or corrode (stainless permanently under water) so carry a couple of spares. And tie the rudder to the unit, if you have a pin problem the rudder could fall off and it will sink.
The few minor problems I've mentioned are rare (we have only had a corroded pin) and the rest of the advice was given to us by other Hydrovane owners.
Ours drives the boat in light to heavy airs with no problem. Others have said to us that they've had problems but it always turned out to be sail balance. You must balance the boat before engaging the vane. In fact the vane is a good test of sailing skills. Hope you enjoy it, I suspect you'll love it.
  #8
Old 04-04-08, 09:45
Phoenix of Hamble's Avatar
Phoenix of Hamble Phoenix of Hamble is offline
Registered User
Looks great.
Out of interest, why did you remove the ladder rather than go for an off centre installation?
__________________
Formally known as Morgana
  #9
Old 04-04-08, 11:00
Jonny_H's Avatar
Registered User
We decided a centred installation would be best - it is easier to install (you can use the rudder to get a true vertical alignment), plus we felt that whilst you can install off centre the boat would perform better with the main rudder and Hydrovane rudder in line.
We didn't realise we would have to remove the ladder until we went to drill the second hole in the bottom bracket - the first hole went in fine, but the second fell right behind the ladder so we couldn't get the drill in!
Fortunately when we put the ladder back in the same place it cleared the Hydrovane unit by about 1/4" so is fine and still perfectly useable - we were fortunate that the stand off brackets on the ladder were so deep to allow the Hydrovane bracket to sit behind them.
Jonny
__________________
  #10
Old 04-04-08, 11:52
david_brighton's Avatar
david_brighton david_brighton is offline
I'll be interested to hear how the Hydrovane performs Jonny.
By the way, is your arch welded to the pulpit or standing on it's own legs?
__________________
Is August a sailing month?
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
