Go Back   Yachting and Boating World Forums > Forum archive > Fouled sterngear reports requested
Fouled sterngear reports requested Please help us ascertain the current threat of badly marked fishing pots, fishing pots secured by dangerous gear and rubbish in the water by placing your reports here.
Thread Tools Search this Thread Display Modes
  #1
Old 05-09-08, 11:15
ski ski is offline
Default Fouled Stern Gear Raz de Sein
Calm conditions, motoring 4-5 kts,Engine stopped with a bang-42 HP Mercedes. 1 1/4" prop shaft bent. We sailed/towed into Morgat where it was removed. The Ambassador rope cutter couldnt cope with the poly prop. The Sterngear was replaced in winter. The following season, engine stopped outside Cherbourg, timing gear train had slackened causing bent pushrods, Excellent and expensive repairs carried out by Cap Loisirs. Expert opinion advised the unit although it had only done 360 hrs since installation ,should not be trusted. Shock loading of stopping a 42 HP engine dead should not be under estimated. So another unit was installed and the gearbox stripped and repaired. 2 holidays ruined thanks to a French fisherman. I later learnt that it is common practice to cut off the worn out cods end which we picked up and throw it overboard. It did serve as a climbing frame for the grandchildren !
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
