Go Back   Yachting and Boating World Forums > Forum archive > MBM red diesel campaign
MBM red diesel campaign A forum dedicated to Motor Boats Monthly's forthcoming Red Alert campaign for the retention of the current rate of duty on UK-supplied marine diesel. Read more here.
Thread Tools Search this Thread Display Modes
  #1
Old 03-02-09, 17:18
davidpetertucker davidpetertucker is offline
Default Red Diesel The Law?
The wording prescribed by HMR&C for this declaration is:-
"I declare that [ ]% of the fuel purchased will be used for propelling a private pleasure craft"
and the declarant will be asked to pay the full rate of duty on the declared proportion of the fuel purchased.
I think it is important to note that the law requires higher duty to be paid on the fuel used for propulsion. This is not the same as the fuel consumed by the engine. Only about 25% of the fuel can strictly be defined as producing actual propulsion, the rest is wasted as heat and noise, the generation of electricity etc. If the law required that higher duty be paid on all the fuel that was consumed by the engine then that is what it would say. It is not our duty to interpret what our rulers may or may not have had in mind, but only to obey the exact letter of the law.
  #2
Old 03-02-09, 17:45
jofb's Avatar
jofb jofb is offline
Default Re: Red Diesel The Law?
I also wonder why there are not two agreed notional splits between use for propulsion and domestic needs - one for motorboats and one for sailing vessels.
The splits must be significantly different, assuming that the sailors are making proper use of their free propulsive force, of course!
__________________
Jof
Grey Goose - Hanse 400e
  #3
Old 03-02-09, 18:14
Sandyman Sandyman is offline
Registered User
Liveaboards. !!!!!
Last week I topped up & claimed 10% for propulsion. 90% for domestic use.
Did I sail up from the West Country to Poole or did I motor against the Easterly winds ??? Did I have any choice other than not to make the passage ?? Did I use any of the fuel from the lower duty paid fuel ??
I shall carry on claiming this split until the nasty man from Customs comes after me.
  #4
Old 04-02-09, 12:38
Nickcf Nickcf is offline
Registered User
Why would it be different..? If you are sailing you are not using fuel. If you are using the engine, you are. This is nothing to do with how much fuel you use (or don't) covering a specific distance. The split is a ratio (60:40) not an allowance or specific amount. Hence it doesn't matter if it is a sailing boat or a mobo. The only issue is what % of your fuel that you are using is for propulsion as against domestic. In theory this is down to efficiency of the engine (the waste heat arguement applies if used for heating water etc) and other use for generators, heating, alternators, battery charging etc).
It would be virtually impossible to calculate a specific ratio for every type of boat (given the type of engine setup) and it would probably change depending on external temperature, type of cruising etc. Hence the 'agreed average' 60:40 ratio. For once a very sensible, pragmatic approach by a gov dept! If the 60:40 is not correct for the type of boat you have you can opt to claim any % from 0-100% so long as you can justify it!
  #5
Old 04-02-09, 18:33
I don't agree. There is no requirement that fuel not used for actual propultion is not taxable. Thus you would be perfectly within yor rights to claim exemption for 75% of the fuel consumed by the engine and 100% of the fule used for heating etc.
The thing to do is not to make too much fuss about it (for fear that the gov will tighten up the wording) but have the argument ready should you be challanged by some scientificaly illiterate revenue man.
  #6
Old 06-03-09, 07:11
rubberduck's Avatar
rubberduck rubberduck is offline
Registered User
If the nice man from the revenue comes to see me, I will tell him I only use the boat as somewhere to bring the girlfriend so the wife does'nt find out, hence only use fuel for warming her up. love to see them get out of that one [img]/forums/images/graemlins/laugh.gif[/img]
  #7
Old 06-03-09, 14:15
duncanmack duncanmack is offline
Registered User
Having had some recent experience of HMRC's modus operandum I'd bet that they would check with both your girlfriend and your wife.
Remember that they'd get more tax "take" from the lawyer's fees from the divorce, and the stamp duty.
Look on the bright side. You'd owe her less now that the price of houses and boats has dropped...
And if you have a pension she'd be getting less than before...
Always try and look at the positive side of things!
__________________
Orrabest
Duncan
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
