Go Back   Yachting and Boating World Forums > Motor Boat Forum
Motor Boat Forum Jointly hosted by Motor Boat & Yachting and Motor Boats Monthly
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 03-07-09, 11:51
AllanG AllanG is offline
Registered User
Default Autohelm Personal Compass
Does anyone use an Autohelm Personal Compass....if so, can you recommend it?
Does anyone have such a compass (in excellent condition) that they wish to sell?
Many thanks,
Allan
  #2
Old 03-07-09, 11:53
catalac08 catalac08 is offline
Registered User
Location: handforth, cheshire uk - boat Fareham (temporarily)
Default Re: Autohelm Personal Compass
used one for 18 years - never changed battery - it switches itself off after a couple of minutes - excellent bit of kit - you can pick them up s/h for 20-40 £.
  #3
Old 03-07-09, 11:55
Elessar's Avatar
Elessar Elessar is offline
Registered User
Yes and no. It is so sensitive that where you stand on the boat makes a big difference to the reading. May be my boat, if so they are very easy to read and use.
__________________
The Antifoul Removal Company
  #4
Old 03-07-09, 16:20
VicS's Avatar
VicS VicS is online now
Registered User
[/ QUOTE ] where you stand should have the same effect on any hand bearing compass, surely ?
What I seem to remember about the Autohelm compass is that it is very important to hold it level.
__________________
Old Chemists never die. They just fail to react
  #5
Old 03-07-09, 17:24
halcyon's Avatar
halcyon halcyon is offline
Registered User
It has a front and rear sight, so should auto level.
The one big advantage is that it will store upto 6 bearing, these can then be replayed when you get back to the chart table. It also has back lighting for night use.
Brian
__________________
Kddpowercentre designers and purveyors of fine charging systems for 30 years.
Powercentre spares and help line
  #6
Old 03-07-09, 17:29
VicS's Avatar
Registered User
[/ QUOTE ] Maybe care is also needed to hold it level sideways. Just something in the dim recesses of my mind ( or the recesses of my dim mind!).
__________________
  #7
Old 03-07-09, 18:29
halcyon's Avatar
Registered User
Down the boat to-morrow, will try.
If I can get the MD6a started I may be able to check it in the water next week, tips on bleeding gratefully recieved.
I think it's a swigs and roudabouts thing, is the posibble error with the Autohelm, worse than trying to read a swinging handbearing compass.
Brian
__________________
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
