Go Back   Yachting and Boating World Forums > Practical Boat Owner's Reader to Reader
Practical Boat Owner's Reader to Reader Share practical, hands-on information, hosted by Practical Boat Owner magazine.
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 03-07-09, 13:19
nigelmercier's Avatar
nigelmercier nigelmercier is offline
Registered User
Default Volvo Penta MD22 Wiring - Earth Relay?
I've re-drawn the Engine and Instrument Panel wiring diagrams for my Volvo Penta MD22, see here.
I'm still confused over one aspect, the Ground Relay. With the Instrument panel diodes installed, this relay seems to fire when either the Start or Stop function is activated, putting a ground onto terminal 31 on the Starter Motor, which is already at ground potential.
Any ideas why?
__________________
Nigel
  #2
Old 03-07-09, 14:22
exfinnsailor's Avatar
exfinnsailor exfinnsailor is offline
Registered User
Location: Nottingham .. About as far as you can get from the sea
Default Re: Volvo Penta MD22 Wiring - Earth Relay?
Total Rubbish Deleted ..
Start again .. Pin 8 drives the relay so when ever the key is in position S or 19 the relay will be on .. So if you take the diodes out it will not work .. Its not connected to anything anyway ..
__________________
There must be hundreds of sailors waiting for the dawn of a new day and as many watching the sunset on one departing .. Happy Sailing wherever you are ...
  #3
Old 03-07-09, 14:23
skipper_stu's Avatar
skipper_stu skipper_stu is offline
Registered User
On mine there is a ground relay, it is to activate the electric windlass, it is a piss poor installation, done by the original dealer i think, i took it out of the equation, the windlass stopped working!
I think it is to prevent the windlass being used when the engine isnt charging
Stu
  #4
Old 03-07-09, 15:23
Hoolie's Avatar
Hoolie Hoolie is offline
Registered User
I have a similar arrangement on my Perkins Prima M50 (same engine). The engine is therefore normally isolated from battery negative and is not earthed. I have always assumed it avoids the need for anodes in the cooling system and reduces other possible sources of corrosion.
It's a nuisance though as isolated starter and alternator are much more expensive [img]/forums/images/graemlins/frown.gif[/img]
  #5
Old 04-07-09, 11:48
Registered User
Ah, that makes sense. The switched ground tag has been removed on my boat, and the engine is indeed grounded.
Bond everything, it's the only way! [Expecting many, many replies saying the opposite] [img]/forums/images/graemlins/smile.gif[/img]
__________________
Nigel
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
