Re: FURUNO 1623 RADAR
If the antenna is definitely turning, then the set is in transmit mode and you should get a picture. Have you run the diagnostics, section 2 of the manual? The only other suggestions are to ensure the brightness/contrast of the display are turned up, although if the menus are showing this is probably OK, and to make sure the cable connections are all good, by tightening the plug and checking the ones you've made in the radome. If these don't help, then you may need to get back to Cactus.
Add; The manual describes a voltage check you can do on the magnetron after installation, might be worth doing, but mine worked "out of the box".
Further thought, have you cut the cable to install it? This would be a very likely problem area.
