Go Back   Yachting and Boating World Forums > The Thames Forum
The Thames Forum A place to discuss boating issues specific to the Thames and other inland waterways
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 04-07-09, 22:29
heron heron is offline
Registered User
Default Speeding boats
Just a question, why is it that the bigger the boat the faster you think you can go ? I`m not talking about planning speeds , but have sat here today and seen several boats going faster than the limit creating massive amounts of wash. The limit is surely there to prevent excessive wash and damage to banks and boats. I know we all sometimes go a tad over 8kph but surely when you can see moored boats you look at the wash you create and slow down ?? Is this not just common sense and courtesy to other users ? It seems as well the larger the boat the less they care and cause more wash. This evening I saw one boat in a "River Rage" incident overtake a narrow boat at around 10 knots just to beat him to a mooring !
Come on guys lets have some consideration for other users of the river before I start naming and shaming, and yes , I have started video ing some boats so it will end up on u tube !
  #2
Old 04-07-09, 22:51
whisper whisper is offline
Registered User
Default Re: Speeding boats
Don't think size has anything to do with it. There are loads of helmsmen with fixed necks, unable to turn around, on small boats as well.
I was messing about on our boat yesterday and could see a dory approaching from downstream. Its bow was well skywards with it being just off the plane and it was trailing a large wake. As it got level with me I saw it had HARBOUR MASTER written on its side!!!!!!
  #3
Old 05-07-09, 09:46
Cuchilo's Avatar
Cuchilo Cuchilo is offline
Registered User
They need the speed to help them steer you see . Its a natural thing , the same as you standing on the bank shouting "wash" at every boat that passes [img]/forums/images/graemlins/grin.gif[/img]
__________________
Dont come running to me if you fall over and break your leg .
  #4
Old 05-07-09, 11:26
apollo's Avatar
apollo apollo is offline
Registered User
If you have photos and you think they were speeding, then report them to the EA?
This is almost a carbon copy of your last post from end of May.
  #5
Old 05-07-09, 20:16
BillyBloater's Avatar
BillyBloater BillyBloater is offline
Registered User
Heron,
Is your boat a rowing boat by any chance?
Billy
__________________
"He is not only dull himself, he is the cause of dullness in others."
  #6
Old 05-07-09, 23:35
jadeflyer jadeflyer is offline
Registered User
The important thing is wash not speed though they are related hence the 8kph limit. A small speedboat at 8kph causes a much larger wake than a large river cruiser at say 10 kph because of its hull design. The other thing is direction and speed of the stream. I note that if there is a fast stream of say 2kts, boats coming upriver are speeding and have large wakes. The likely reason is that their speed logs are faulty and they use GPS for speed indication. So if GPS says 8kph, stream is 3kph then boat speed is 11kph hence large wake. I find if I go downstream with my 13mtr river cruiser I do need at least 6-8 kph boat speed for effective steering but with a 3kph stream it appears from the bank I'm speeding and get waved at, but I have no wake at all. I've always wondered if the EA account for stream when they check the speed of a boat, it certainly should be factored in.
  #7
Old 05-07-09, 23:37
No Regrets's Avatar
No Regrets No Regrets is offline
Registered User
The speed limit is over ground anyway, so GPS is OK isn't it?
__________________
BCC's Boat handling Champions 2009
BCC's Top Family entrants 2009
BCC's Best Crew 2009
BCC's Top Newcomers 2009
YBW Forum Mouth'n Trousers award 2007-9
We have No Regrets!
  #8
Old 06-07-09, 00:01
Brayman Brayman is offline
Registered User
It is OK in legal and measurable terms but just plain stupid.
__________________
Brayman
http://www.braycruiserclub.co.uk
  #9
Old 06-07-09, 10:26
DogsBody's Avatar
DogsBody DogsBody is offline
Registered User
GPS is more than ok, because the limit is 8KPH speed over the ground, you have to use GPS indicated speed, your log gives speed through the water so is no help in sticking to the EA's limit.
That said, as Brayman states, sometimes even sticking to the speed limit is stupid due to the amount of wash you are creating, conversely you can sometimes be speeding but making very little wash i.e. going down river in red board conditions.
__________________
Help save your local lock keeper www.saveourservice.org
  #10
Old 06-07-09, 10:29
byron's Avatar
byron byron is offline
Registered User
I whole heartedly agree with you Ian. The first mistake was to couch the speed limit in terms of kilometres instead of the world standard of knots. The second was its very introduction. As example, a Broom Ocean, Continental or European cannot be considered to be under full control at less than 5 knots. Ergo navigating one safely means one is breaking the law. Yet at 5 knots they leave little wake. Far better the previous system where an Inspector used his judgement as to whether a vessel was causing too much wash or being driven dangerously.
__________________
www.alexander-advertising.co.uk
  #11
Old 06-07-09, 10:47
Chris_d's Avatar
Chris_d Chris_d is offline
Registered User
Are you sure about that Byron, afterall most close quarter manouvering is done at less than 5knts and Brooms seem to just sit where you put them at virtualy zero speed. I know where you are coming from though and certainly in any coastal harbour or channel with a swell going 5knts would present problems, but I do feel some owners use this as justification for speeding.
  #12
Old 06-07-09, 11:04
byron's Avatar
Registered User
Perhaps I didn't quantify my statement Chris. Whilst they are all lovely docile boats to handle at close quarters. Directionally they require 5 knots for adequate steerage.
__________________
  #13
Old 06-07-09, 14:59
phild501 phild501 is offline
Registered User
Agreed that a quoted speed limit only solves part of the issue. Hull shape makes a massive difference, relatively large boats (say the salters trip boats) can crack along whilst barely raising a ripple whilst the average planing hull would create wash you could surf on at the same speed. A speed limit is measurable and therefore enforceable, consideration for other river users is neither.
  #14
Old 07-07-09, 20:13
Registered User
Know what you mean about needing some speed for steerage, my own boat is on an outdrive so have the same issues. My gripe from the post was that it is becoming so regular with speeding boats that I`m starting to get fed up with it all. Surely common sense dictates that if you create a large wash you slow down past moored boats irespective of speed ?
I regular see boats large and small coming steaming down , see my boat and don`t slow down, yet when they get to the 24 hour moorings where others are moored they slow down.... Just seems they don`t give a damn sometimes
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
