Interesting.....
I have not seen the book.
The classical method of dealing with minutes of arc in Lat or Long is to interpolate.
I will explain:-
Conventionally 6' of arc = 1/10 of one degree.
Then between one level of latitude and another in whole numbers thre is a correction applicable to each.
Then in this case one correction is subtracted from the other and then the fraction in difference is applied to give an accurate value, which is called an "argument"", with which to be able to carry on the calculation accurately.
The same applies for Longitude.
I hope this helps.
