Go Back   Yachting and Boating World Forums > The Thames Forum
The Thames Forum A place to discuss boating issues specific to the Thames and other inland waterways
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 31-10-09, 10:30
Mark M Mark M is offline
New User
Default replacing Boat furniture
Hi
I`m hoping can give me some help with there knowledge, expierience.
On my Birchwood 33 I have an old plywood varnished kitchen area, which is fine, but is now very tired looking.
I measured it and it would be quite easy to rip it out and replace it with standard house kitchen type units and worktop.
My only concern is that as my boat doesent have the power/heating over the winter to keep the boat warm inside, and its in the water over the damp winter months.
I am concerned that the laminate will eventually peel off the chipboard units!!!.
I normally just leave all plywood cupboards/doors open, but am not sure about the chipboard/laminate units.
Any helpful advice would be appreciated
Cheers Mark
  #2
Old 31-10-09, 11:02
Chris_d's Avatar
Chris_d Chris_d is offline
Registered User
Default
Quote:
Originally Posted by Mark M View Post
Hi
Cheers Mark
I would definately never use ordinary chipboard or ply from a DIY store, as you have suggested it will not stand the damp environment and will swell and split. I've seen the results in some older boats and its a right mess. Unfortunately the only way is to use rather more expensive treated marine ply, wood or even stone worktops etc.. and never use chipboard at all.
  #3
Old 31-10-09, 11:28
boatone boatone is offline
Registered User
Default
Quote:
Not sure I completely agree.
Exterior grade ply will last a long time and I have used chipboard on an earlier boat and it was still fine several years later. Doesn't like wet conditions but a well aired boat doesn't get that damp!
Having said that, its amazing how some new laminate can transform existing tatty work-tops.
A lot also depends on how long you intend to keep the boat - as long as it looks good when you sell it .....
__________________
Yet another gem from an old fart with attitude .........
  #4
Old 13-11-09, 00:11
micheal.rock@gmail.com micheal.rock@gmail.com is offline
New User
Default Galley worktop
[QUOTE=Chris_d;2294622]I would definately never use ordinary chipboard or ply from a DIY store, as you have suggested it will not stand the damp environment and will swell and split. I've seen the results in some older boats and its a right mess. Unfortunately the only way is to use rather more expensive treated marine ply, wood or even stone worktops etc.. and never use chipboard at all.[/QUO
My galley had a plywood backed white laminate which rotted due to a leak. Is it possible to buy marine grade ply with white laminate on one side ?
  #5
Old 31-10-09, 14:30
Ramage's Avatar
Ramage Ramage is offline
Registered User
Default
I looked over a Birchwood 33 (Navarra Star) where they had removed the all in one metal sink/drainer/double burner n grill and fitted a domestic style worktop with a sink/drainer let into it. They had fitted a stand alone cooker. It looked good and was a neat job.
I have also seen boats where the original has been rubbed down & revarnished to good effect. Some people even paint the units!
  #6
Old 08-11-09, 09:29
andythilo andythilo is offline
Registered User
Default
I'm doing this soon on my boat. Kitchen area is old and tired with a crappy white rusty oven hob and 70's worktop.
Gonna rip it all out and install some nice B&Q units, do away with the oven and put in a 12v microwave (hidden behind a door) and twin hob along with a small sink/drainer. Then i'm gonna put a smoked glass hinged lid over it all (toughened glass of course).
Mind you I am gonna install some tube heaters to keep it warmish over winter.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
