I've put my wing-keeled Dehler 35 alongside the scrubbing posts a couple of times.
The posts are on a gentle slope, which means that when the boat takes the ground, she leans into - or away from - the posts, depending on which side I lay her, so you should allow for that.
Even if she leans out (which looks odd, if not slightly alarming), I lash the base of the mast to one of the posts, just in case.
I'm not sure I'd dry out alongside a wall without having a look at the wall base first, in case it protrudes or the bottom slopes away too steeply.
I hope this helps.
