Go Back   Yachting and Boating World Forums > Motor Boat Forum
Motor Boat Forum Jointly hosted by Motor Boat & Yachting and Motor Boats Monthly
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 02-11-09, 18:21
Converging Converging is offline
Registered User
Question What exactly Is a VM Diesel
I have a Sealine fitted with two 3.6 Mercruiser engines but I keep hearing a reference to them being VM Engines. Research shows VM engines are made in Italy or that they are fitted to Land Rovers. I thought mercruiser were American! Whats the truth or am I on the wrong track completley?
  #2
Old 02-11-09, 18:31
PCUK PCUK is offline
Registered User
Default
No, you are right. VM are made by VM Diesel in Italy. You can probably Google them.
  #3
Old 02-11-09, 18:34
neale's Avatar
neale neale is offline
Registered User
Default
Good or bad engines, depends who you listen to. VM lumps were fitted in early diesel Range Rovers and have been used in Rovers (SD1 and 825), Fords (Scorpio) and Jeeps (Cherokee). Probably others as well that I have forgotten.
Marine wise they were the base engine for the 80's BWM diesels and the slightly later 6 cylinder MerCruiser engines.
I quite like them. Got one in my Range Rover. Very easy to work on. Separate cylinder heads on each cylinder. Basic and simple. Known to clock up huge mileage in cars as long as they are looked after.
Biggest problem is overheating leading to head problems. Keep em cool and regularly serviced and they should keep going.
__________________
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ.
  #4
Old 02-11-09, 18:57
DownWest DownWest is offline
Registered User
Default
Range Rovers imported to Portugal (and Discos) were fitted with VMs and didn't have a stella reputation. Friend had broken rockers and big bills. Don't know about Mercruiser tho.
A
I think you are right about Jeeps with VMs, untill MB bought them and fitted CDI lumps.
  #5
Old 02-11-09, 18:58
tinkicker0's Avatar
tinkicker0 tinkicker0 is offline
Registered User
Default
Quote:
Sure you are not getting em mixed up with GM?
Most Mercs are based on General Motors lumps, eg 3.0l = GMC Iron duke 4 banger.
4.2l = Chevy V6.
7.2MPI = Chevvy V8
http://www.gm.com/experience/technol...est_121208.jsp
__________________
I've only got a little one.
  #6
Old 02-11-09, 19:06
Firefly625's Avatar
Firefly625 Firefly625 is offline
Registered User
Default
4.2l = Chevy V6.
7.2MPI = Chevvy V8
PCUK & all are right, VM diesels are indeed Italian and were fitted to Range Rovers in the 4 cylinder format, as Neale stated separate cylinder heads, which are of course a little unusual meant that the basic same engine is used with a couple more cylinders added for other applications, in this case marine. Had some issues with the cylinder heads going slightly out of alignment in vehicles and they then started to make a "tweating" noise.... well that's the only way we used to describe it! But pretty sound, heavy engines, some big mileages done....
__________________
OOOOH HOW RUDE!
  #7
Old 02-11-09, 19:10
volvopaul volvopaul is online now
Registered User
Default
Hi your sealine will have either the 180hp 3.6 litre engine or the 4.2 litre 220hp version, it was marketed and marinised by mercruiser, but as costs to design and build engines are astronomical some companies use a base / stock engine as there model.
BMW marine used the same 180hp d636 vm motori engine, IMHO there not a good marine engine better suited to the industrial use they were intended for in the first place.
Some parts are getting scarce like simple parts like anodes for the coolers etc.
When first introduced to the marine world the heat exchangers were so small they overheated, things improved with the addition of separate oil coolers, but they are only just on top of the job, the engines dont suit some boats like brooms or larger princesses, and were later dropped from the options list in favour of volvo and yanmar engines.
  #8
Old 02-11-09, 19:37
rafiki_ rafiki_ is offline
Registered User
Default
VM Motori are Italian, and have had various owners over the years, including MV Augusta, Chrysler (part owner) and now Gaz International (Russians who killed off LDV Vans in B'ham). Most marinisers do not design or make the base engines, including Volvo Penta, who have sourced from a number of places. Mercruiser petrol engines are generally US Big 3 sourced, and they dabbled in some diesels, and have now joined forces with Cummins, called CMD.
I have 2 CMD units in my boat, based on Isuzu engines. If you are careful, you can source some base engine parts from the original manufacturer. I have used Isuzu oil and fuel filters sourced from the van dealers, having previously paid a fortune for the Quicksilver boxes from Swindlers!!!
  #9
Old 02-11-09, 20:42
Latestarter1 Latestarter1 is offline
Registered User
Default VM Ownership
VM were effectively owed by the Italian government until 1998.
Chrysler were purchasing increasing volumes for the Voyager and was approached by the Italian government who wished to get out of ever increasing R&D expenditure.
Chrysler not wanting to get into engine manufacure but at the same time needing to secure supplies invited Cummins and Roger Penskie owner of Detroit Diesel to bid. Following due dilligence into the products Cummins walked. Now in a one horse race Penskie scooped up VM for a song and wound it into his Detroit Diesel empire.
However Detroit was already in deep do-do with the US EPA over cheat strategies on truck emissions and following a huge fine under the EPA Consent Decree Penskie was washed up. Detroit and sold out to Mercedes, who already owned a stake in Detroit. For sale notice went up over the door again, engineers at Stuttgart had no time at all for VM designs. Whoever refered to VM being heavy is completely wrong, always a light motor in their displacement node.
Mercedes managed to sell 50% to GM for use in cars produced by their Daewoo operation in 2007 and then disposed of the other 50% to GAZ some time after.
Mercruiser had a long term supply agreement with VM for marine engines. VM produce the complete marine unit, however they are bound by the terms of the supply agreement only to sell marine engines in certain markets, for example Italy.
With the advent of the Cummins/Mercruiser deal they were bound by a long term supply agreement between VM and Mercruiser, despite the fact that Cummins had already had the books opened up to them when they had done due dilligence back in 1998 and had not liked what they had seen.
  #10
Old 02-11-09, 21:43
Registered User
Default
Very Interesting mr latestarter that answers my thoughts as to why cummins and mercruiser joined together, I had thought about trying to push out volvopenta.
I dont think anyone ever will push vp out, the japanese are trying there best but as of yet the outdrives are still not up to vp standard, imho nether are mercruiser.
Interesting your post about hp figures on yanmar, I always compare how broom boats seem to go better with the yanmars rather than the equivalent rated hp volvopenta.
  #11
Old 02-11-09, 23:25
Registered User
Default Volvo Vs Yanmar
Slightly off topic,
however old generation Volvo 40 and 60 Series were a also bit flaky on power but were a little shy on out right urge, then Yanmar LP's and LY's came along. It was all about the WAY Yanmar delvered the power rather than the actual numbers. VM 4.2 and Volvo KAD 44 could never match Yanmar LP on one and two second torque, period.
With new generation common rail engines D4/6 etc Volvo got real, understated rather than overstated power and deliver some serious one and two second torque figures. VM 4.2 common rail in CMD QSD format can now also be taken seriously.
Yanmar has gone backwards, new generation LP's with retarded timing are pussy cats if you stand them up against fire breathing old LP's.
LYA3 with its £3,500 cost to overhaul fuel pump is almost a bad joke. It requires the dealer to manually set the AFC (Air fuel control) with the lap top. You can have vessel which takes off like a scalded cat but produces clouds of black smoke. Or you can have one the in opposite AFC position not wanting to get out of bed, getting it right costs service $$'s, then you get a fouled bottom.
As for outdrives consider this; ZF are #1 in marine gearboxes, toppled Twin Disc years ago. However good ZF is, what happened when they got into making outdrives, utter disaster.........
US market fast becoming polarised CMD/VP at expense of both Yanmar and CAT, however the CMD QSD(VM) is STILL stuggling to gain acceptance??
  #12
Old 02-11-09, 23:42
Registered User
Default
wow guys so much information!! Does this mean I can source parts from normal motor factors to avoid paying silly marine prices and if so what model engine would they need to know as a reference?
  #13
Old 03-11-09, 10:37
davedpc davedpc is offline
Registered User
Default
I have little trouble getting engine spares from VM from chesterfield Tel. 01246 455350. Think they are on holiday until next week.. Like the Volvos the lower hp engines are unstressed but as they squees more and more power out of the standard blocks using cleaver electronics and fueling etc. it is then that problems occur.
  #14
Old 03-11-09, 19:38
Registered User
Default
Converging, you will need to know the base engine spec to source parts from motor factors. If you can find the serial no of the engine, then this should be possible. Then consider if the part is likely to be marinised. Alternatively check the part on the engine currently. My expensive Quicksilver boxes came complete with Isuzu branded parts and numbers. No brainer to replace. Belts have Isuzu brand and numbers on them. Engine internals I'm not so confident about, so will stick with Isuzu consumables, and hope never to replace the mechanicals.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
