I am always fitting generators and come across your problem a lot.
I also attend jobs where the genny has seized as its been stood idle withe sea water in the bores, the last one had no waterlock just the hose pointing up towards the sky then back down to the silencer, hence net result.
Looking at your problem the 32 inch run up hill is out of the question, the longer the run of hose the more water in the pipe to run back when the engine is switched off, so keep the run of hose from manifold to waterlock as short as possible.
Can you not fit the waterlock at the side of the engine with a very short run to it.
I also see many builders especially aft cabin boats that have problems and cannot use the manufacturers exhaust elbow, therefore one has to be made to inject the water further down the line where it points downhill, thus the new part has to be a dry exhaust that has to be lagged with a jacket, Broom boats have to do this a lot.
I would look at doing a short dry run if you can and make up the mixer head further down the run if that helps.
