Go Back   Yachting and Boating World Forums > Liveaboard Link
Liveaboard Link Especially for those who live on their sail or motor boats, or are planning the great escape from bricks and mortar. Hosted by Yachting Monthly magazine
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 03-11-09, 20:54
sjclewes's Avatar
sjclewes sjclewes is offline
Registered User
Default d400 on a mizzen mount
hi there has anyone mizzen mounted a d4oo wind generator and if so have any pictures and comments regarding the installation also if i made a bracket out of stainless would it cause corrosion against the alloy mast
  #2
Old 03-11-09, 21:38
paulclan's Avatar
paulclan paulclan is offline
Registered User
Smile
I replied to this post on the Practical Boat owner forum.
you seem to have posted in two locations which makes for waste of space!
__________________
"C'est Formidable"
"He who dips his wick must needs pay for oil"
  #3
Old 03-11-09, 21:54
sjclewes's Avatar
Registered User
Default
hi there im sure this is the livaboard link so the more ideas the better
  #4
Old 04-11-09, 00:32
paulclan's Avatar
Registered User
Default
Hi sjclewes,(too tired to argue)
Should be easy enough, use a paste between the s/s bracket and the alloy mast, your rigger or chandler will advise (some use plumber's mate goo!)
more importantly the data with the wind generator will indicate the type of fasteners and the size to be used.
I'd imagine monel metal will be the choice of rivet material, and being tough will need a lazy tongs type rivet setter or one with arms about 2 feet long.A big grunt will be needed and be careful with your thumbs when the shank pulls out of the set rivet.The leech of the main should be well away from tangling with the unit, but as it is best mounted well up the mizzen there should not be a problem with this issue.
My pal has done this with an Oyster Mariner 35 Ketch and is well pleased with the installation.
Good sailing and boating to all.
__________________
"C'est Formidable"
__________________
"C'est Formidable"
  #5
Old 04-11-09, 05:55
charles_reed's Avatar
charles_reed charles_reed is offline
Registered User
Default
Use Duralac and monel rivets, to prevent it being immovably jammed.
SS to anodised aluminium doesn't necessarily mean any corrosion - -it's the fixings that cause the trouble.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
