Go Back   Yachting and Boating World Forums > Practical Boat Owner's Reader to Reader
Practical Boat Owner's Reader to Reader Share practical, hands-on information, hosted by Practical Boat Owner magazine.
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 07-11-09, 06:09
Csail's Avatar
Csail Csail is offline
Registered User
Default Inverter
For running computers etc do i require pure sine wave or modified?
__________________
Also new product that disperses rain off glass.And a new product to restore crazed polycarbonate windows.
Still doing vinyl boat names if you need any.
Supplier of BIC boats and inflatable kayaks.
http://www.h2o-marine.co.uk
By the way any orders have a contribution to Cancer Research UK.
  #2
Old 07-11-09, 07:07
William_H William_H is offline
Registered User
Default Inverter type.
That is a difficult question to answer. I think when people start to answer from experience you will get stories of computer power supplies burning out and others that work fine. Perhaps your best bet is to try before you buy. However the queer waveform of the "modified sine wave" inverter can cause all sorts of problems with induction motors like that of a refrigerator where the higher frequencies of the square waves will cause heating of the motor a huge inefficiencies. So to be sure your computer is OK onn the inverter you choose you need to be able to measure the primary (12v) current to the inverter. Any gross inefficiencies which result in overheating of the computer or inverter will show as excessive primary current.
You should expect to use approx 1.4 to 1.8 times as much current into the inverter as the AC load in watts would indicate. This allows for inefficiencies but any more might indicate a problem.
I think if you can afford it you would be better off going for a pure sine wave inverter or if it is possible substitute the lap top charger for a power converter 12v to 18v or whatever is required.
Good luck I ma sorry I am not much help olewill
  #3
Old 07-11-09, 22:21
Playtime's Avatar
Playtime Playtime is offline
Registered User
Default
Quote:
You don't actually need an inverter. A simple (and more efficient) way is to use a DC to DC converter like this one from Maplin
http://www.maplin.co.uk/Module.aspx?ModuleNo=36836
You need to check what input voltage your laptop needs (19V is quite common) and also what plug type (the converter comes with several different 'ends' but some laptops use a special plug that may be difficult to source).
[PS Ignore the above if you are using a desktop PC and not a laptop!]
__________________
Loves sailing, hates gardening.
  #4
Old 07-11-09, 23:53
VicMallows VicMallows is offline
Registered User
Default 12v or 240v Inverter?
I've had no problems whatsoever running the laptop (19v) via it's mains PSU and a cheap (£24.99 from NETTO) 150W inverter. This will most certainly not be 'pure-sine-wave'!
I've also used DC-DC converters (technically these are inverters also, but they change the output back to DC) with mixed results. I've had two of the very common cheap ones -(about 2inx3in, curved at top and straight at bottom) which both failed after a couple of hours.
I have another, smaller and rectangular, which has had extensive use over last year and works perfectly (this one has assortment of funny little plastic plugs which select the output voltage).
The DC-DC is more efficient, and has lower idle current that the 240v inverter, so generally use it for the computer. However, it creates a lot of interference if listening to internet radio relayed to the car radio! .....so have to change back to the 240v. Oh! Well.
Vic
  #5
Old 07-11-09, 23:18
saxonpirate's Avatar
saxonpirate saxonpirate is offline
Registered User
Default
Agree totally with Playtime. You don't need an inverter to run a laptop aboard. Total waste of time and power. The 12 volt DC adaptor will do the job admirably. How can I be so sure? Because I use one when not on shore power, and have done for a few years.
Don't get sucked into the inverter jungle.... I nearly did. But after doing a lot of research and then listening to a friend who's an electronics engineer, I paid my tenner or whatever it cost then and have had trouble free 12 volt usage ever since.
__________________
Beneteau First 35 for sale : http://beneteaufirst35.blogspot.com/
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
