News from YBW.com
Go Back   Yachting and Boating World Forums > Practical Boat Owner's Reader to Reader
Practical Boat Owner's Reader to Reader Share practical, hands-on information, hosted by Practical Boat Owner magazine.
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 04-06-03, 23:46
webcraft's Avatar
webcraft webcraft is offline
Registered User
Default Continuous line headsail reefing
I've only used standard (rotostay etc) headsail furling systems before, but our Vega has a continuous line system. The maker's name has worn off the drum, so I don't know the make. (I have pix if anyone thinks that would help).
Anyway . . . How is this meant to work?
The system seems to rely on the continuous line being held under considerable tension to stop the headsail unrolling to its full extent when reefed. Today the whole sail unrolled when not required.
The only mechanism for tensioning the furling line is to wrap it round a cleat or two, which is variable in its results, not very quick and not very efficient. (There is about 6" of slack in the line).
Is this standard, or is there a better way?
- Nick
<hr width=100% size=1><font size=1><A target="_blank" HREF=http://www.bluemoment.com>http://www.bluemoment.com</A></font size=1>
__________________
Web Design Scotland
  #2
Old 04-06-03, 23:53
Gunfleet Gunfleet is offline
Registered User
Default Re: Continuous line headsail reefing
It's what I have and the way you describe using it is dead right. It is less than perfect. Whenever I leave the boat I put a sail tie around the headsail, just in case.
  #3
Old 05-06-03, 00:19
webcraft's Avatar
Registered User
It's not when I'm away I worry - I always take a wrap or two of the sheets round it - but I am very concerned about the vessel spontaneously deciding to increase the sail plan at an inconvenient moment.
I was wondering about a pair of jamming cleats side by side . . .
- Nick
__________________
Web Design Scotland
  #4
Old 05-06-03, 00:19
alanporter alanporter is offline
It is likely a Hood LD (Line Drive). I have one on my Westerly Renown, chosen by the previous owner. I wouldn't have one again, but it is too expensive to change. One can reef the genoa by tightly cleating the line down, but the slightest slackness in the line will allow the sail to suddenly unfurl.
<hr width=100% size=1>Alan Porter
__________________
Alan Porter
  #5
Old 05-06-03, 00:27
Registered User
My boat came with tufnol cam cleats to do the job, but I felt it was less likely to spontaneously 'change the sail plan' if I took a great big bight of the wretched thing and secured it much in the way you'd secure a sheet. Of course since my boat is of a certain age she has plenty of large, strong cleats handy next to the cockpit.
  #6
Old 05-06-03, 01:02
HenryB's Avatar
HenryB HenryB is offline
Registered User
If it's the Hood LD as Alan suggests then I have one fitted to my Westerly and it sometimes slips. Hood offer an upgrade to single line operation on their site at
http://www.hood.com.ar/sistemas/importado.htm
presumably because of the slippage problem.
Using cleats to keep the rope tight and ensuring that the rope doesn't get worn seems to minimise the problem but, of course, when it does slip it's always in the worse conditions. Once, on a long beat, I even resorted to tying the drum so that it couldn't slip, so much for the convenience of roller furling.
Do let us know if you come up with a solution.
Regards,
Henry
  #7
Old 05-06-03, 09:33
DeeGee's Avatar
DeeGee DeeGee is offline
Registered User
Knowing abs. nothing about this, I wonder couldn't you have a short auxiliary line which you seize onto the reefing line with a prussic or a rolling hitch?
<hr width=100% size=1>Black Sugar - the sweetest of all
__________________
This post is intented to be an expression of good humour. Any implied aggression or bad-feeling is totally due to the medium and not the messenger.
  #8
Old 05-06-03, 11:35
snowleopard's Avatar
snowleopard snowleopard is offline
Registered User
these gadgets are very sensitive to type/size of line. they will never be 100% reliable but it's worth experimenting to see what gives best grip.
when cleating it's essential to keep both ends of the line in tension. you could make them up together on a single cleat.
__________________
One hull good, two hulls better.
  #9
Old 05-06-03, 11:37
steve_cronin steve_cronin is offline
That is just how mainsail in-mast continuous line reefing works. However you will need to part the line so as to be able to thread it through the cleats or obtain a pair of cleats which have a removable cheek or jammer mechanism.
Steve Cronin
  #10
Old 05-06-03, 11:55
jimi's Avatar
jimi jimi is offline
Registered User
what I'd do is feed the the line through a spinlock clutch, that should give you much better control.
Reply
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
