Go Back   Yachting and Boating World Forums > Forum archive > Yarmouth get together May 2006
Yarmouth get together May 2006 A forum to help everyone planning or attending the get together in Yarmouth
Thread Tools Search this Thread Display Modes
  #1
Old 11-10-05, 22:17
Posts: n/a
Default For those new to Harold Hayles ....
Enter Yarmouth Hbr and transit between first run of pontoons and row of pile moored yachts .... follow this pontoon line round until you see bridge ahead of you .... there will be pontoons either side of you as you proceed .... last pontoons on right are HH .... opposite the Dinghy stage ....
BBQ area is to the north on the sand spit inside breakwater .... see chartlet above !!
<u>To Talbot</u> ..... Cat 9m = £25.50 incl electric / water ... but they need to know beam .....
  #2
Old 11-10-05, 23:29
Talbot's Avatar
Talbot Talbot is offline
Registered User
Default Re: For those new to Harold Hayles ....
Beam = 13' 9" or 4.19m
£25 = 150% for a boat only just wider than a normal mobo of that length and considerably narrower than some 45 ft boats that would pay the same amount - robbin bar stewards. I dont mind paying a rate that is pro rata the same as anyone else, just pisses me orf when they take the mick like this - probably why I dont normally use UK marinas.
__________________
"Be wary of strong drink. It can make you shoot at tax collectors - and miss."
Robert A Heinlein
  #3
Old 12-10-05, 09:46
rickp rickp is offline
Registered User
I found that some of the places I visted in Holland recently (Willemstad springs to mind as one) charged for the box you occupied (so LOA * breadth) which seems pretty fair for all.
Rick
__________________
Elling E3 for sale
  #4
Old 12-10-05, 11:37
Talbot's Avatar
Registered User
agree, a charge based on volume has to be fair to everyone.
__________________
Robert A Heinlein
  #5
Old 12-10-05, 10:55
bedouin bedouin is offline
Registered User
I think you're getting a fair deal - you're 13'6 compared to my 9'6 and we're roughly the same length. You are 50% wider and pay 50% - that sounds fair!
Now what is unfair is that most marinas charge by the linear foot, when the should charge by the product of length and beam [img]/forums/images/graemlins/smile.gif[/img]
  #6
Old 12-10-05, 12:01
galadriel's Avatar
galadriel galadriel is online now
Registered User
But you do have TWO keels in the water [img]/forums/images/graemlins/wink.gif[/img]
__________________
"You are young and life is long and there is time to kill today
And then one day you find ten years have got behind you"
Roger Waters 1972
  #7
Old 12-10-05, 12:08
Talbot's Avatar
Registered User
No I dont, I dont actually have any keels!
__________________
Robert A Heinlein
  #8
Old 12-10-05, 13:25
galadriel's Avatar
Registered User
OK OK then hulls!
You must float on something!
__________________
Roger Waters 1972
  #9
Old 12-10-05, 14:02
Talbot's Avatar
Registered User
Will accept hulls - [img]/forums/images/graemlins/laugh.gif[/img].
Its all a question of design - when my class were designed they were at the cutting edge of technology and used a V shaped hull create the resistance to leeway. Later design breakthroughs discovered that a U shaped hull was a better load carrier and if you added a long low aspect ratio keel underneath you got better resistance to leeway and much better directional stability..
The one advantage of the V shape is that a very strong gust lifting a hull not only reduces the resistance to leeway from the hull that is out of the water, but also considerably reduces the resistance to leeway from the hull that is in the water. If you are sideways on to a very large wave, you can feel the boat slide sideways.
Also too much sail = too much leeway
__________________
Robert A Heinlein
Bookmarks
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
